Originally Posted by
big_G
This picture shows the reason the wing failed. Insufficient support structure around the wing tube. It simply ripped the ribs right out of the wing. There should have been a spar box built around the wing tube, not in front of it. Simply poor engineering.
Your correct, I looked at every wing I have that use a tube (8 or9) and this is the only one with the tube not built into the spar structure. I don't think the tube is to short for the intended service. Question now is what is the best way to correct this defect. Looks like I will have to strip the bottom covering off and move the tube forward with supporting structure to transfer the load to the spar. Not a huge project but....
