Originally Posted by
philipat
thanks for the diagram. But, what does the two-pin lead between the airsoft gun and the control board do?
That is the contact switch that signals the airsoft unit has been fired and that the motherboard needs to perform track recoil and output cannon sound. If you disconnect it you will not get a track recoil when you fire, nor will you get sound.
