See
http://en.wikipedia.org/wiki/Kerosene
Kerosene is usually called
paraffin in the UK,
Ireland,
Southeast Asia and
South Africa.
[h=2]Properties[/h] Kerosene, a thin, clear liquid formed from hydrocarbons, with a
density of 0.78–0.81 g/cm[SUP]3[/SUP], is obtained from the
fractional distillation of
petroleum between 150 °
C and 275 °C, resulting in a mixture of carbon chains that typically contain between 6 and 16
carbon atoms per
molecule.[SUP]
[8][/SUP]
Regardless of the crude oil source or processing history, the major components of all kerosenes are branched and straight chain
alkanes and
naphthenes (cycloalkanes), which normally account for at least 70% by volume.
Aromatic hydrocarbons in this boiling range, such as
alkylbenzenes (single ring) and alkylnaphthalenes (double ring) do not normally exceed 25% by volume of kerosene streams.
Olefins are usually not present at more than 5% by volume.[SUP]
[9][/SUP]
The
flash point of kerosene is between 37 and 65 °C (100 and 150 °F), and its
autoignition temperature is 220 °C (428 °F).[SUP]
[10][/SUP] The
pour point of kerosene depends on grade, with commercial aviation fuel standardized at −47 °C (−53 °F).
