The section of the engine that needs cooling most is the cylinder and ideally one should try to direct incoming air in and around the cylinder fins. The other area of major concern is getting rid of hot air from the exhaust as quickly as possible, hence the rule of thumb of having the exit hole 3 times the size of the inlet, not always necessary depending on the install but a good reference point.
Karol
