Not trying to spend someone else's money, but you will probably want at least two batteries so one can be charging at the field while you are flying the other one. Then, of course, you will need a balance charger to charge them and a twelve volt source to use at the field. I use a garden tractor battery from Walmart that cost, I believe, $26.00. It adds up in a hurry.
