RCU Forums - View Single Post - Turbo Prop question
Old 09-21-2014 | 02:53 AM
George
My Feedback: (57)
Originally Posted by 4ptroll
Can you guys tell me how you are connecting your exhaust pipes to the turbine. I have a set of Tam's pipes and I'm not sure of the best way to connect them.
Larry
I'm not sure about others, but if the "fit" is tight enough, a clamp works great. I did add 2 small screws to prevent any movement in any direction or from coming off in case it loosened up. You can see the one screw in the pic, the other is around near the clamping screw. I think this pic was taken before the second one was put in place.
