Originally Posted by
rrembert
So there you are with your pilot certificate in your back pocket, flying your 100-150cc whatever (with a spotter), doing rollers 5 ft off the ground having a great time, when an FAA guy drives up and says you are acting with "reckless endangerment"...hmmm...
Really? That sounds more paranoid that reasonable. Usually the FAA would not get involved until after a complaint is filed. The only question that the FAA guy could ask is, "Are you endangering the NAS in some way?" If you aren't, then you have no problem or concern.
