Final approach.
When at the final approach what should I do ?
Should I let the plane loose altitude with the elevator level (so it goes down but gains speed) and then flare it about 2 feet off the ground ?
Or
Should I try to keep it level all the way to the ground and flare it 2 feet off the ground until is goes down ?
At the moment I do the second but I bounce a lot on landing.
Or maybe they are both wrong and I should do something else ?
