Check your throttle end points and idle setting. Set to 100/100 and no sub trim . Idle must be 0. When you turn on you should get beeps automatically if you're using single channel operation. If using two channel operation you have to do the beeps manually each start. If the ecu is a stock one there is no teaching needed.
