The JC30 has a choke that is spring loaded and will 'lock' in place if the throttle is in idle - but with the closeness of those two pushrods, that arrangement is not possible due to the geometry. If the spring on the choke is removed, what will stop the choke from closing during flight? Hummmmmm...anyone have a suggestion and pictures would be nice
I noticed the throttle arm has a vertical movement in addition to its forward/backward movement - thinking of using ball link with a "U" pushrod, first going forward, making a "U" turn and back to the servo. The choke arm on the other hand has more of a vertical movement to engage.....how have you seen this situation resolved?
Jerry
