RCU Forums - View Single Post - Need AMT engine/ECU programming help !!
Old 09-26-2014 | 06:49 PM
yeahbaby's Avatar
yeahbaby
My Feedback: (21)
You bet, happy to help.
if you had an EDT you could verify 0% = idle 100% = full throttle
Set throttle channel throw 100% /100%
low rate beep is off
mid rate beep is shut down ( with momentary cool down )
high rate beep is run
should be the same as an old style ECU
