RCU Forums - View Single Post - TF Cessna rear window
Old 10-08-2003 | 02:11 PM
RCHYFLYER
Default TF Cessna rear window
Aruuugg lol in the instructions for the TF Cessna they want you to install the rear window
before the building is finished! I want to glass this plane so do I leave the window out? The window has to be covered or painted to give the impression it is part of the planes framing. Should I leave it in and glass slightly over the edge to help hold it in place! I would like to make the transfer from body to window a clean transition! Will the resin attack the plastic or should I use balsa filler?
