Originally Posted by
jws_aces
I flew at 305mm first time. That is what the manual calls for. That was with no extra weight. It was nose heavy in flight. I ended up moving the 2 life 3600mah batteries from under the front seat to behind the main gear doors. moved turbine battery back from the nose to under rear seat. Still will not hold a wheelie very long on landing but flies much better inverted.
I trying to lose more weight in the nose. The cockpit and pilot provide plenty of wieght up front.
