still need to tweak the throws a little. for normal shutdown, lower the trim slowly, when you get to the right spot (normally the middle) the engine will rev slightly for a few seconds then will shut off and start cooling sequence when rpm gets to about 2500. you are getting emergency shutdown which is past normal shutdown.
