RCU Forums - View Single Post - Limp track
Thread: Limp track
Old 10-06-2014 | 12:40 AM
AELock's Avatar
AELock
Originally Posted by ausf
You could delve deeper into the source, whether it's something in the gearbox or motor. I'd look over the slow side, check the lubrication, look for obvious sources of binding, check that the frame is square and that there's no rubbing anywhere, especially near the final drive shaft.
Couldn't hurt to take the tracks off to compare tension as you spin the sprockets and look for evidence of track rubbing on the hull on the offending side.
There's no reason to put up with bad steering.
I'm currently working on that but I've hit another road bump, would you kindly tell me how to remove the drive sprocket? I was only able to remove first part of the wheel, the one being held by a screw.
