RCU Forums - View Single Post - Gas engine Question
Old 10-08-2014 | 11:00 AM
slamn sammy's Avatar
slamn sammy
Thanks guys for the input. l understand and l'm kinda thinking the same way, BUT! l have been known for over powering things. I have a RCShowcase 180/30cc gas that no one seems to know anything about? Can not make it run? Has Fire, Gas, BUT! Will not even bark? The timing (Hall Sensor) is in the rear of the case, could not adjust the timing if l needed too. They made two versions of this engine. One with the carb, in the front and one with the card in the rear and that is the one l have. Two bad i'm not a fishermen, it would make a good trotline wight!! Guess l'll set on it a bet. HAY!! I GOT A SUPER TIGER 4500!! NO!! That would not work! 6+Lbs + Two Flights Per Gal. Burns 40+Oz glow fuel in (8) mins!
