I love this radial ignition experiment. Want one! But...I'm still trying to wrap my head around EIGHT magnets. Are you sure you didn't count #1 twice? Why wouldn't #1 be #8? 1,3,5,7,2,4,6,1,3,5,7,2,4,6,1,3,5,7,2,4,6,1....... etc? Also, have you checked to see if the ignition module is truly firing in sequence? Or are more than one plugs firing at the same time? I would assume that each plug fires once when it should, and a second time harmlessly on the exhaust stroke. Because the unit doesn't know if a cylinder is on compression or exhaust. More detailed info would be great.
