RCU Forums - View Single Post - Not Happy with Lanier Razor 3D
Old 10-08-2003 | 09:59 PM
dbow's Avatar
dbow
Default RE: Not Happy with Lanier Razor 3D
o.k I put the mounts on and I see what all of you are saying about the angle and the offset of the firewall. So I guess I will just have to beef up the cracks with a little epoxy and be done with it.
I think I will go back to the hobby shop with this plane and get some advice because my engine wont fit correctly with the mounts. The mounts are not wide enough for the OS .46fx to fit into unless I tighten one side of the mount down and then place the engine in and tighten down the other side. One mount ends up out of line and is not paralle with the other. I am unsure if I am doing something wrong though.
Im actually not going to use the .46 but rather a .50SX in this plane. The .46 is what I have laying around I wanted to see how it would fit.
So far I am not please with this ARF but I will wait until it gets in the air before I make a final conclusion.
Thanks for the info
Dbow
