RCU Forums - View Single Post - Help on DX18 sequencer...please...
Old 10-19-2014 | 11:00 AM
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by ashworthb
One more question. I'm using Robart electric retracts in my Corsair and I can't figure out how to program the sequencer (DX18) to provide a long enough delay between the door open cycle and the door closing. I'm using the default "door cycle / wheels 1A".
Just use the default sequencer as an example and create a new sequence with as much time between gear and doors as you want. You should also be able to use more than 2 channels, assuming you have them free with a separate nose wheel door that behaves differently than the others if you want. Using separate channels for each door, again assuming you have the channels to spare, would also allow you to use the travel adjusts, etc, for those channels to adjust full open / closed positions of servo operated doors, etc.
