RCU Forums - View Single Post - Help on DX18 sequencer...please...
Old 10-19-2014 | 04:32 PM
ashworthb
Originally Posted by wfield0455
Just use the default sequencer as an example and create a new sequence with as much time between gear and doors as you want. You should also be able to use more than 2 channels, assuming you have them free with a separate nose wheel door that behaves differently than the others if you want. Using separate channels for each door, again assuming you have the channels to spare, would also allow you to use the travel adjusts, etc, for those channels to adjust full open / closed positions of servo operated doors, etc.
I'm using a JR. Matchbox to handle the four servos for the doors. When you say create a new sequence "with as much time between gear and doors as I want" I can't figure out how to get the delay I need between actions. On the gear up cycle, I have the doors open between points 1 & 2, the gear down between points 2 & 3 and the doors close between points 3 & 4. Nonetheless, the doors close before the gear is up. I can't figure out how to extend the delay?
