Originally Posted by
ashworthb
I'm using a JR. Matchbox to handle the four servos for the doors. When you say create a new sequence "with as much time between gear and doors as I want" I can't figure out how to get the delay I need between actions. On the gear up cycle, I have the doors open between points 1 & 2, the gear down between points 2 & 3 and the doors close between points 3 & 4. Nonetheless, the doors close before the gear is up. I can't figure out how to extend the delay?
Sorry, ignore the create a new sequence comment, I was confusing the sequencer in the DX18 with the sequencer in my other radio. As has already been said, when you choose a sequencer it has forward speed and reverse speeds. If you want 5 seconds between the door opening and the gear extending then do something like set a speed of 10 seconds and if the doors open at the start of the sequence (point 0) then have the gear extend at 50%(point 1). The times are just for illustration purposes, chose what ever times you want for the forward and reverse speeds and set each point to the appropriate percentage of that time.
