Originally Posted by
phlpsfrnk
Here we go again.
Will you at least agree that in Class G airspace flight is governed by VFR flight rules?
Frank
Only when flying in a certified aircraft above minimim altitudes, flying below minimum altitude is breaking a big rule. If not certified, such as a hang glider, you can follow other rules, not the FAA but probably the hang glider CBO. We should be following the AMA. And I suspect eventually drones flying below minimum altitude will be following some other CBO rule.
