Here are the pics of the finished lite ply center sheer webs, You may also notice the ply wing bolt mounts.
Th two center ribs are glued together, This is a mod from the pland, as they are not glued in at an angle. The angles isn't necessary, as there is no dihedral.
The middle ribs were then cap stripped. This was done to bring them to the same height as the rest of the ribs. Later, I will sheet the center section an extra bay, over stock. The wing leading edge will be sheeted, so the ribs will need to be cap stripped to bring them to the same height.. This will happen later.
