This morning, I finished the sheer web installation.
I weighted the wing down, to keep it flat. The balsa sheer webbing, as per the plans, was installed to both the front and rear spars.
I then added balsa scrap to fill in the area above the ply wing bolt mounts. The bals will be saturated in thin CA, after sanding. This should provide a tough enough surface to insure that the wing bolts do not crush the wing.
]I just got all call. I'm going flying !
