RCU Forums - View Single Post - hen long wiring problem
Old 10-28-2014 | 11:27 AM
Imex-Erik's Avatar
Imex-Erik
Originally Posted by maxu52
If it's leaking it needs to be replaced. This is what you need
http://www.imex-model.com/product/TA...IT.html?cid=90
It may be close to new, but I can see at least two mods that have already been done to it, moving two of the switches and remounting them so they're accessible through the driver and a-drivers hatches. I'm pretty sure Imex doesn't do that yet, but I'd have to check with Erik to be sure.
Yes the new tanks have the sound knob and smoke switch under the driver's hatch now Thanks to my RCU'ers for that one!
Also, thanks for beating to this, I am still trying to get caught up at work and then I can go full out RCU again! The smoke unit can most likely be fixed if it just ran out, but since they are cheap it would probably be easier to replace. I would suggest a bit of hot glue around the edges to keep it sealed up nice and good. I also superglue the output tubes in place to try to contain the smoke fluid as well.
