RCU Forums - View Single Post - engine mounting
Thread: engine mounting
Old 10-31-2014 | 11:58 AM
p3arljam
Default engine mounting
I am assembling an ARF with a nylon motor mount and a Saito 72 . There are no pre drilled holes and i want to make sure i do everything correctly. #1 does anyone know if the great planes dead center tool is worth buying? #2 the holes i drill should they be tight when the bolt goes thru like the same diameter as the bolt or should they slide freely all the way thru?
