RCU Forums - View Single Post - engine mounting
Thread: engine mounting
Old 11-09-2014 | 08:27 PM
N410DC
Originally Posted by DGrant
... I'm thinking its a 6/32 size needed for that size engine.. double check me on it.. If your kit came with bolts.. theres a good chance they're metric of some sort... I probably wouldn't use them.. I'd get some Dubro machine/allen bolts... and the Dubro tap/drill set... ...
I used 6/32 bolts to mount an OS .72 Surpass 4 Stroke. The bolts fit the mounting holes well, and held the engine firmly in place. I used the Dubro drill/tap set. It worked like a charm.
Originally Posted by 52larry52
The Great Planes Dead Center Drill is one of the handiest tool you could put in your tool box! They are great for getting the holes correctly positioned on many model mounting jobs: engines, eng. mounts, servos, control horns, switches, you name it! Buy one!
I have used this tool on three planes for the engine mounts and servos. It is one of the most indispensable tools I have!
