RCU Forums - View Single Post - TIGER MOTH 40 (ARF) E conversion
Old 10-10-2003 | 02:35 AM
westridge
Default TIGER MOTH 40 (ARF) E conversion
I am not sure if I should have continued from my P51 Post ? Anyway I have now thought about maybe going for a TIGER MOTH 40 (ARF) and converting it to e power.
the specs on the plane are as follows:
Wingspan: 54 in (1375mm)
Wing Area: 899 sq in (58 dm2)
Weight: 6.2 lb (2810g)
Wing Loading: 15.8 oz/sq ft (48.3 g/dm2)
Fuselage Length: 44 in (1122mm)
Requires: 2-stroke .40-.46 cu in (6.5-7.5cc) or 4-stroke .48-.53 cu in (8- 8.5cc) engine, 4-channel radio w/5 servos
I would like to put in the same power system as I was going to use for my P51 D ARF
Maxim N32-13Y brushless motor and controller
MEC 4:1 Superbox gearbox
Power supplied by lithium cells.
will this work well ? Also what is a Tiger Moth capable of doing in the Air as far as crowd pleasers (And crashing does not come to mind)
