Originally Posted by
mikes68charger
I agree I got 3 of these IceMan gyro in my skymaster f15 1/9, and Top Flite Gaint P40, and FW190
I really love its flexibility and how it can cut your reciver channel's needs down
Having gains on each axis is important to me as my war birds have the gains on high on the rudder and mid on elevator and ali but the f15 is low on ali and mid on elevator and rudder
I want to try it out on my eurosport also but I don't know.
Im still not sure how to set the iceman on the dekts wing yet
As the iceman only gives you 2 slots for elevator but when running in delta mode you are putting one elevon in the elevator slot and one in the ali slot. So this leave one open elevator slot open for the canards
Is this how to cortex works?
On the Cortex, you simply connect the channels to be stabilized (up to 5), matching the order of the inputs and outputs, then run the setup procedure. There is no specific aileron, elevator or rudder channels. You simply setup your transmitter and receiver to operate the controls as desired and when you perform the setup procedure, the Cortex determines the controls and what needs to be done to stabilize them..
