RCU Forums - View Single Post - Need some help with KV-l
Old 11-28-2014 | 02:08 AM
Bagheera's Avatar
Bagheera
I took the tracks and the rear drive off and it was the screws you mentioned. A big tank you. The top screw is for the upper hull and the screw at the back is for the rear plate
All the mounts an cross braces will be cut out for a flat deck with metal sides. A steel plate will replace the battery door for weight.
Johnny
