Need some help with KV-l
Old 11-27-2014 | 01:24 PM
Bagheera's Avatar
Default Need some help with KV-l
Hey
I just got my 15th tank a KV-1. I need some help, how do I separate the upper and lower hull. Have the front screws out but what's in the rear? I got the metal hafts for it hatches for it, know where the 2 go but what about the other 2?
Tanks
Johnny
__________________________________________________ __________
HL Pershing x2, Sherman 75mm, Tiger 1, KT (P),PantherG/Jadg, Stug.lll, Pzrlll x2, PzrlV, Leopard 2A6M Can, KV-1 Tam Sherman E9 and a Mato Sherman Soon M1 Abrams
Never have enough toys
He who dies with the most toys wins
Old 11-27-2014 | 06:48 PM
Airbrushler's Avatar
is it an HL, under the rear fenders you might have to take the tracks off to get to them
Old 11-27-2014 | 06:50 PM
Bagheera's Avatar
Thank You good sir I try that
Johnny
Old 11-27-2014 | 06:55 PM
they are almost just in front / behind the rear drive sprockets
if that makes sence...lol
Old 11-28-2014 | 02:08 AM
Bagheera's Avatar
I took the tracks and the rear drive off and it was the screws you mentioned. A big tank you. The top screw is for the upper hull and the screw at the back is for the rear plate
All the mounts an cross braces will be cut out for a flat deck with metal sides. A steel plate will replace the battery door for weight.
Johnny
Old 11-30-2014 | 01:30 AM
Hello Johnny , I have several KV's , all converted to some degree . Be careful of adding too much Weight - the HL KV suspension is OK for an all plastic set up but if you add metal - gearboxes , tracks etc. the rear end gets very heavy and the springs may not cope ( My best KV has a metal hull + black steel 4 to one gearboxes , absolutely bombproof ! )
Old 12-02-2014 | 08:03 AM
Imex-Erik's Avatar
We have the metal hull if you need, it is VERY tough.
