On a BiSide I built for a friend, I constructed similar incidence changing shims in order to bring the top wing into correct relation to the bottom wing (can't remember the number, but it was specified by BJ).
I let the strut shims set/control the top wing incidence, then added the center pylon wood as a support that did not effect the incidence. I suspect that is what the new kit does.
Dan
