RCU Forums - View Single Post - BJCraft BISIDE
Old 12-07-2014 | 10:04 AM
  #497
shannah
Originally Posted by ltc
I'm a bit confused regarding the new wing incidence kit.
Are the 8 laser cut 'wedges' show on the bottom of the new wing incidence kit (that I assume mount on the fuse center pylon)...4th pic in Mike's post #489
http://www.rcuniverse.com/forum/atta...0&d=1417883308
the same as those that were previously provided for the top wing hold down kit (shown at the bottom of the BiSide assembly guide under "Add Up")
http://rcone.kr/upload2/files/data/d...e5c3c32/b2.jpg
http://rcone.kr/upload2/files/data/d...e5c3c32/b3.jpg
In other words, if you have already installed the top wing hold down add up, do you need to remove those pieces from the fuse pylon and install the new pieces?
I can't tell if they are the same by looking at just the pictures. I thought earlier in this thread it was said that the top wing carry kit cdnter pylon pieces did not change incidence, but the new kit does?
Thank you very much.
Yes, you remove the old center pylon shims and install the new ones. As Dan states, you first install the shims on the wing struts (top) then position the center pylon shim so that it contacts the wing center.
