Originally Posted by
Greg Wright
Just using the hottest tap water you can get does the same thing. You don't have to boil the water.
I've used this method for years, before i started just using all of the PPG product line.
Ive used hot water poored out of the tap with good results but the best results were with a heat gun about 6in away
PS if you over heat the can the bottom of the can pops/bulges out for safety
