RCU Forums - View Single Post - Servos for recoil and elevation
Old 12-14-2014 | 04:35 PM
Tanque's Avatar
Tanque
Default Servos for recoil and elevation
I've read some of the threads that cover using servos as recoil units. Is the only way they are used is in a channel coupling mode?
Has anyone semi 'hacked' a servo to use it as a small gear motor directly without a control board to be controlled by a TBU, Clark or any other BU?
( by semi hacked I mean without an small external pot needed to center the unit to be used with a radio system.)
Just curious if it's been done.
Jerry
