RCU Forums - View Single Post - Engine problem. help
Old 12-16-2014 | 06:25 AM
  #31
jerdavis's Avatar
jerdavis
sounds like the idle mix or midrange needle valve is too far open allowing fuel to run back into the tank. Or there could be an air leak in the idle mix system ( bad o rings) this carb has at least three orings on idle needle/ spray bar mechanism. The orings could be worn or cracked from drying out.
Jerry
