An engine thats been sitting around will normaly have some issues with the old caster oil left over from the last run, simply clean out the carb and flush engine with new fuel reassemble carb with new o rings replace glow plug, plug that hole, start engine with the needle valve out 3 turns and tune from there, the fuel is the best thing to clean out old caster , after all thats what put it there in the first place..........
