RCU Forums - View Single Post - Covering question...
Old 12-16-2014 | 09:17 AM
jeff4912
Thank you for the responses. I will probably cover one at a time with a square and work around them. Next time, I will install them later after covering.
Speedracer, I will see if I can get more CA under that glass area that has air under it. I like the idea of extending the CA out to the wing mounting joint. I already have dents near the rear hold down bolts from test fitting.
Can I reinforce that wing mounting saddle area with only thin CA and no glass? Kind of like reinforcing a screw hole, or control horn with CA?
Just rub the CA on with a rubber gloved finger?
