RCU Forums - View Single Post - Engine problem. help
Old 12-16-2014 | 08:19 PM
  #38
vertical grimmace's Avatar
vertical grimmace
Just an FYI, if you did not know, the 2 clunk system is known as Uniflow venting. Common with control line models. You want one clunk attached to your carb line, and the other clunk connected toy your muffler pressure line. Not your fuel dot. This helps maintain a consistent needle setting throughout the tank level. Typical problem is to go lean as fuel level drops. This eliminates this issue.
