RCU Forums - View Single Post - Engine problem. help
Old 12-17-2014 | 04:20 PM
  #43
vertical grimmace's Avatar
vertical grimmace
If you run your drain line (fuel dot) to the bottom of the tank, it will do it's job. It does not need the complexity of a clunk added, to properly drain the tank.
It is imperative to have the vent line, or entire tank for that matter, sealed. No leaks.
Most R/Cers do not know about this type of venting, but it is superior to the standard method. It is standard in CL stunt flying.
Anybody ever fly a CL plane? The engines go lean at the end of the tank, if a standard vent is used. Any successful CL model is either using a Uniflow tank, or a pressure system.
