RCU Forums - View Single Post - Covering question...
Old 12-17-2014 | 06:14 PM
Zor
Banned
BLUE TEXT BY Zor
Originally Posted by sensei
So let me get this straight, after the bond line has dried utilizing CA there is only between 10 and 20 percent of adhesive left in the joint due to the capillary nature of wood.
I described my experiment with CA on a piece of clean metal to see how much solid remained after curing. How much solid was there to fill any small gap. The best fit we can make does not have perfect full area contact. A 1/8" square balsa (0.125" x 0.125") will have on one side a gap of 0.0022" if only one (1) degree out of perfect angle. That gap has to be filled with cured glue, not with air.
A crashed landing will survive much better if glued with anything else besides CA because only the covering is holding the airframe together in reality.
You wrote "anything else" _ _ _ this anything else has to be good satisfactory glue for the application.
I never wrote that
only the covering is holding the airframe together in reality. I wrote that I read that from someone who wrote it. There might have been some exageration in that writing.
Personally I much prefer to use some brand of wood glue that has a good proportion of solids left after curing, that is not creating any nasty human reaction (vapor inhalation) that allows time for positioning pieces and result I believe in much stronger joints particularlly when filleted properly.
Thank you for that informative information Zor I will use this to my advantage on my next build..
Bob
Bob,
You will soon see the gluing of the Kadet Senior that I am beginning to build the wings.
Zor
