RCU Forums - View Single Post - Foam Wing Ringmaster?
Old 12-21-2014 | 08:15 AM
ochsnm00
Default Foam Wing Ringmaster?
I cut out and sheeted a pair of Ringmaster foam wings. They turned out well. Does the bellcrank have to be mounted inside the wing? I can do it but don't want to if I don't have to. What determines the lead out exit point, is it the thrust line? Can the bellcrank be mounted outside the wing and then rout the lead outs through the middle of the wing tip?
Name:	Ringmaster Parts 003.JPG
