RCU Forums - View Single Post - Heng Long RC Range problems
Old 12-22-2014 | 10:25 AM
YHR's Avatar
YHR
Originally Posted by BadBill
OK, I got the DBC / BARC and installed it by the directions yesterday. Very easy, but it became immediately apparent that everything was plugged in wrong- wrong sticks activating wrong functions. I am using a JR 9303 2.4 transmitter, so I figured maybe the drawing was just for Futaba channel order. Tried moving things around, but ended up just getting more confused- which channel should control firing/recoil? When I had everything hooked up one time the recoil worked with the elevator stick, but if I change that channel to the throttle stick on the left it doesn't work? Am I going to need to play with end point adjustments or something ? Seems like the unit will work good but there is something I don't understand LOL.... Thanks for any help ya'll can give!
I will help you. Because people have there own personal preferences the connection to the receiver can always lead to trouble. Let me know how you want your radio to function and then we can work at getting the servo's plugged into the right spot on the receiver. ie what stick do you want for throttle and steering I am guessing they are mixed up.
Do you have a spare servo??? This can help in identifying servo function,
Did I email you an operation manual.?
