RCU Forums - View Single Post - Starting screws and nuts in tight places
Old 12-23-2014 | 08:30 AM
Villa's Avatar
Villa
A trick that I use is to always make a small hole for the screw. Sometimes I make a spade drill from a thin piece of piano wire by hammering flat one end and with a file turn that end into a point so that it will cut into soft material. It is now a SPADE DRILL. I chuck the wire in my electric hand drill and will bend the wire as needed to go around obstructions.
