Originally Posted by
adanjo
>Does the bellcrank have to be mounted inside the wing?
No. You can mount the bellcrank anywhere you want.
>What determines the lead out exit point, is it the thrust line?
No. It is C/G.
>Can the bellcrank be mounted outside the wing and then rout the lead outs through the middle of the wing tip?
Maybe possible, but extremly difficult.
Why don't you mount the bellcrank and the leadouts inside the wing?
Or, mount the bellcrank and the leadouts outside the wing?
Aki
Okay so I can mount the bellcrank and the leadout under the wing? That's my preferred method.
