Hi Guys, for the ones that were talking about the Gear and fitting, after a lot of fiddling around, I decided to grind the corner of the plastic cover on the knuckle and 2MM from the edge of the landing gear where it was hitting the fuse. this would give me 0.5 degree toe out each side and makes everything fit perfect. here are a couple of pictures for reference. One after sanded and one after covered and painted. From the front view, they are hard to see.
Behzad
