RCU Forums - View Single Post - Foam Wing Ringmaster?
Old 12-23-2014 | 03:44 PM
aspeed's Avatar
aspeed
The leadouts should be slightly behind the CofG, so the plane doesn't point in at you. It should point slightly nose down when hanging by the leadouts. Height isn't too important unless it is a very high or low wing. Inside or outside of the wing is just asthetics. Bellcrank position isn't as important as the leadout position.
