Originally Posted by
DUCMOZ
A good screw with that configuration will handle a lot of force. I think other stuff would break before that so there should not be a problem.
Duc moz thanks for the reply, do you use spacers to make the linkage in line with the servo horns or just let it angle inwards?
i started with a white builders kit, did you notice the airfences were to be mounted with a bit of toe in?
Details for scale makes a tank
