Originally Posted by
toti_ducati
Duc moz thanks for the reply, do you use spacers to make the linkage in line with the servo horns or just let it angle inwards?
i started with a white builders kit, did you notice the airfences were to be mounted with a bit of toe in?
Details for scale makes a tank
Hi, there are markings on the wings for the fences. 3 little ones and one wide large one. As for the stab set up, you will be moving the pressure area out if you use spacer and that could weaken the set-up. So it is better to let them be as they are. Please look at post # 412 and picture of my set-up is there.
thanks, Behzad
