a few handling problems
my stadium truck has lots of power and good tires (gladiators) on the front but stock tires on the back.
ive been driving it in bitumin carparks lately tuning etc
it has good turn in but looses the rear end if you turn with speed or power on.
this causes exiting oversteer but you can also loop the car
with little traction i could do a donut or 2 and keep going after i lost the rear but ive fiddled with sway bar stiffness and rear camber to get more rear traction so now when i push too hard and loose the rear end the car flicks backwards and stalls and then freerolls backwards to a stop.
is there any way to stop this stalling and increasing rear traction. ie changing front rear balance, ride height, shock performance. because i cant afford better rear tires
